View fan tray information to see manufacturing information about the fans.
- On the Device Physical View, select the Device.
- Select Chassis.
- Select the Fan Tray Info tab.
Fan Tray Info Field Descriptions
Use the data in the following table to use the Fan Tray Info tab.
Name |
Description |
Description |
Shows a description of the fan tray. |
FlowType |
Specifies whether the air flow is front-to-back or back-to-front. |
